Humax PVR8000T signal corruption after start-up
Discussion in 'Digital TV & Video Players & Recorders' started by SMCC, Aug 29, 2004.
Tags:
  1. SMCC
    SMCC
    I've had a Humax PVR for a few months now and am generally very happy with it. However it has a consistent problem which remains after this w/e's software update.
    After switching on the box from standby the picture and sound is displayed / played clearly but then after about 20 seconds the signal is corrupted with frozen video and digital artefact (like a poor DAB signal) on the sound. This lasts about 20 seconds and then the picture and sound return to perfect quality.
    This happens every time the box is turned on. It blights the start of every recording I've made. I have a top quality signal from a DTV aerial and am within 4 miles of Crystal Palace transmitter. The box does not appear to have any other problems.
    Before I contact Humax, has anybody else here experienced this or a similar problem?
  2. Timh
    Timh
    Sep 14, 2000
    5,236
    3
    3
    Altair-4
    +318
    Mine seems ok. have you tried to do the firmware upgrade again incase it had a problem when it installed, its what i would try. I think the update finishes at 10.00 am tomorrow.
  3. SMCC
    SMCC
    Thanks Timh. firmware update seems fine - displaying correct version no. and all new features present and working (can record radio at last - hurray!). As I said the problem dates from day one of the box's life.
    I Probably should have contacted Humax sooner but it's useful to know if this is a problem others have experienced or just a one-off.
  4. Timh
    Timh
    Sep 14, 2000
    5,236
    3
    3
    Altair-4
    +318
    You could try emailing Humax direct. Here's the address of a guy that sent me the info for the latest update [email protected]
  5. Plugman
    Plugman
    SMCC the box shouldn't do this and after contacting Humax when I had mine they agreed to swop it (Well QED did anyway). So I guess it is a hardware fault if you look on Radio and Telly forum you will see that you are not alone.
    Hope this helps
  6. ajross
    ajross
    Jul 7, 2004
    2
    I had exactly the same problem and logged a report with Humax who have just given me this advice, will be trying it this evening:
    Please can you follow the instructions below to try to resolve the problem?
    1. Press MENU
    2. Select Installation and press OK
    3. Enter your password (default = 0000)
    4. Select Default setting and press OK
    5. Select YES and press OK
    6. Enter password
    The receiver will now take 20-30 seconds and then restart. When it boots up it
    will enter the Automatic Search and search for the channels again.
  7. SMCC
    SMCC
    ajross - just wondering if that fixed the problem? Didn't help me...
  8. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,220
    n/a
    +306
    SMCC,
    I also have the same problem.
    The signal strength always shows between 90-94%,
    and sometimes the quality will drop from 100% to 0% :mad:
    DVD
  9. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +95
    It could be your aerial. The direction that it points in is highly critical and usually very directional (i.e. having a tiny sweet spot)for digital signals. It can show good strength but be marginal as far as quality is concerned. This can present itself as good quality most of the time, but dropping to poor or highly variable quality when affected by external influences, such as the weather, trees, building work etc. You could try repositioning the aerial when you are experiencing problems until you find the direction for max signal quaiity. Just a thought :rolleyes:
  10. Blu-rayx
    Blu-rayx
    Nov 6, 2001
    2,220
    n/a
    +306
    I've never encountered this problem with previous freeview receivers.
    DVD
  11. SMCC
    SMCC
    Likewise. My sony digibox on the same aerial never has a reception problem. The humax always loses the signal approx. 20 seconds after start-up for about a minute, then it's perfect until the next time it starts-up from standby.
