Humax Pvr to dvd recorder
L
longstone
Hi guys this is very interesting forum, please could you help me resolve this little problem.I have just bought a Humax PVR 9200 and would like to link it to a cheapy dvd recorder maybe cyberhome etc, would I be able to record direct from the hd straight onto the dvd recorder. What cable connections should I use ets
Thanks in advance for info..longstone
ROYOLD
Yes - use a scart lead. I record from my Humax 9200T to a Panasonic E85 dvd recorder using just a scart lead.
Connected AV1 (TV) out from Humax into AV2 socket on Panasonic. Works fine.
L
longstone
Thanks ROYOLD for that very quick reply, well the reason for my buying the Humax was a very bad expierience with a cheap ALDI dvd recorder, well two actually, could you recommend a cheap maybe like the cyberhome recorder (there seems so many) to record the odd program I may want to save to dvd
