caniscorpus
I have three of these set top boxes. After a time I find that the hard drive fails and needs replacement. Humax customer services advised that a Seagate DB35.3 series drive should be used. I duly installed this Seagate drive only to find that the same problem recurrs. This is that when menu is accessed the screen does not display Record.Instead the option list starts with preferences and at the end is shown an option for games. As users will know this does not normally display. To get record I have to switch the box off and on. The box then reloads and then when I press menu the Record option magically re-appears. Unfortunately this does not last and for no reason at all the Record function can disappear and I have to switch off and on again. Can anyone tell me if this a hard disc problem or whether there is some other exlanation and cure
