Humax LGB-40TPVR, 699GBP, any user reports please?
Discussion in 'LCD & LED LCD TVs Forum' started by Mr User Name, Apr 24, 2007.
Tags:
  1. Mr User Name
    Mr User Name
    I searched AV forums but no hits came back.
    Cost 699 including delivery and two year warranty. No hdmi input though.
    I do not work for Humax, if it is rubbish, say so.:lesson:
    Spec below from Humax website.
    LGB-40TPVR
    * 40" HDReady Freeview LCD TV
    * Built in 40Gb Hard drive DTV recorder
    * Freeview Twin tuner, record 1 channel whilst watching another
    * Tape-less recording of 30 hours of TV
    * USB 2.0 port for external hard drive, for archiving your favourite TV programmes
    * Pause and rewind live TV
    * Records digital channels, analog channels and external sources eg. SKY or Cable
    * Multiple Screen - Picture in Picture & Dual Screen functions
    * Optical audio out, Virtual Surround audio
    * Computer WXGA Video resolution support (1280 x 768), connectable to computer as a monitor
    * VESA Standard Wall Mounting Support (mount not included)
    Item Description
    LCD
    Type Colour active matrix TFT-LCD
    Display Area 40" Wide
    Aspect Ratio 16 : 9
    Display Color 16.2 M
    Resolution 1366 * 768
    Contrast Ratio 1000 : 1
    Luminance of White 500 cd/m©÷
    Viewing Angle (CR>10) 170° (H) / 170° (V)
    Module Size 952.0 (W) * 551.0 (H) (mm)
    Depth (D) 51 mm
    Response Time 8 ms
    Dimension
    Width * Height * Depth 1,235 * 699 * 252 (mm) - 48.6 x 27.5 x 9.9 (inches)
    Depth (without table top stand) 120 (mm)
    Weight
    Net weight 34 Kg - 75 lbs
    Sound
    Speakers Mono / Stereo / Nicam / A2
    Audio Output 7W + 7W (Max.)
    Power
    Supply AC 90 ~ 240V
    Consumption (working) 300W
    (stand-by) 5W
    DTT System Resources
    Tuner (Analog and Digital)
    Analog Receiving System PAL / SECAM-VS Tuning
    Video Decoder
    Transport Stream MPEG-2 ISO/IEC 13818
    Profile Level MPEG-2 Main Profile @ Main Level
    Video Formats 4:3, 16:9 letter box (Default)
    Audio Decoder
    Audio Decoding MPEG/MusicCam Layer I & II
    Audio Mode Single / Dual mono / Stereo / Joint stereo
    Input / Output
    Video In/Output 3 SCARTS, 1 RCA
    S-VHS Input Mini Din 4-pin jack
    Component Input RCA jack
    DVI Input DVI-D
    PC RGB Input D-sub 15 pin
    PC Audio Input Stereo Jack
    Headphone Output Stereo Jack
    S/PDIF Output Optical
    Smart Card 1 Slot
    Common Interface 1 Slot
    RS-232C 9 Pin
    HDD 40 GB
    USB USB 2.0 Capability to external HDD
  2. son_t
    son_t
    Jan 12, 2006
    1,524
    +176
    It will be like this one: the Humax LDE-40A but with a PVR inside.
    This one is specifically for the UK and will be supported by Humax UK.
    The PVR in these Humax sets are very poor compared to Humax own stand alone PVR - the 9200T.
    Where are you getting your info and price from. Lots of sites are miss-spec'ing these two Humax LCD TVs...
  3. Mr User Name
    Mr User Name
    Info came from Humax UK website
  4. Osamede
    Osamede
    Mar 23, 2007
    805
    28
    +41
    Would you have ever bought a CRT TV with a VCR emedded in it? I doubt it.
    So why would you buy its 21 century equivalent, especially when you know up front that freeview is a dead end technology? It is going to move from MPEG2 to MPEG4, making your embedded "twin tuner" utterly useless.
    I would avoid that move, especially on a big screen TV that you are spending a lot of money on.
