humax lcd
A
aarons
I have been asked to wall mount a humax 17in lcd on the sloping part of a loft conversion.Does anyone know the wall mounts that will fit these or is it any universal mount
J
JonnyFive
Most universal brackets have adaptor plates available to fit any lcd. I would ring a company that stocks the lcd and ask them if its vesa 100x100 or 100x200 or 200x200mm. Then the appropriate adaptor can be ordered if needed. I find the more research you do the smoother things go on install day. Thats the theory anyway. :thumbsup:
challenging
did you have any luck with the 17" humax bracket, I have checked all sorts of sites even humax. Looks in the manual that it is a hook affair.
A
aarons
no not yet bloke doing job for has put on hold for a while will post when I find one
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
