Humax HDR Fox T2 Panasonic FX650 No Audio Solution
PlayItSam
Connected working Humax HDR Fox T2 to new Panasonic FX650 series smart TV using HDMI lead, picture okay, but no sound even with volume on max, via TV HDMI ports HDMI1 and HDMI2. However, picture and sound okay via TV HDMI port HDMI3.
Solution. Change TV HDMI Auto Setting to Mode1.
Please note Humax HDR Fox T2 switched on and connected to TV HDMI port HDMI1.
Steps, using TV remote:
1. Press [AV]
2. Press [▲] [▼] to select HDMI1
3. Press [OK]
4. Press [MENU]
5. Press [▲] [▼] to select Setup
6. Press [OK]
7. Press [▲] [▼] to select HDMI Auto Setting
8. Press [OK]
9. Press [▲] [▼] to select HDMI1
10. Press [OK]
11. Press [▲] [▼] to select
Mode1
12. Press [OK]
13. Press [▲] [▼] to select HDMI2
14. Press [OK]
15. Press [▲] [▼] to select
Mode1
16. Press [OK]
17. Press [BACK/RETURN] 3 times to exit from Menu.
Changing settings for TV ports HDMI1 and HDMI2 allows you to freely swap between the two without loss of sound.
You may just change the setting for the TV HDMI port you have your Humax connected to.
Hope this helps.
Alchemist
Thank you for the excellent, and very concise, step by step solution. It saved me a lot of troubleshooting time.
