dazzlingdaz
Work is being done on this aspect by Humax, although personally I haven't managed to ever make it crash over the network, however I seen a few reports saying similar. Sometimes you just don't know there are issues until it is tested in a wider setting. If you haven't already I would send Humax an email [email protected] with the issues you are having and what circumstances cause it to crash.
Are you on the latest firmware 1.01.09, this has some improvements in this area over prior versions, but more needs to be done so hopefully improvements in the next release which should be in December.
Regards
Phil
I have had it crash a couple of times on me - usually if you are streaming and fast forward and rewind in quick succession.
Another way of causing it seems to be play a recording - stop it - and then start antoher one in quickly.
It's almost as if the change in stream position of the file or requiring of a new file causes the sync to get confused.
This seems to result in the box resetting.
Unfortunately it doesn't look like it may be fixed in the December update as this seems more related to getting the TVportal up and running - which isnt such a bad thing.
We are aiming to get an update out within the first 2 weeks of December, but it is not possible at this time to confirm a date. More than likely it will be released as a Beta prior to the official release.
I also asked about where to send requests / problems to:
Any requests should just be sent into [email protected], however, not wanting to disappoint but there will not be any major/significant changes to the product other than those already planned and obviously any major issues found in the product.
