Breaking Dad
Established Member
Hi all, I have a couple of these Humax recorders which we have used for the last few years, and have proved to be simple to use and reliable. Recently however I have noticed that on both machines you can no longer adjust the volume on the HD channels using the Humax remote? The slider bar still appears on the screen and you can adjust it, it just makes no difference to the volume, you have to use the main television remote. However you can still adjust the volume on the SD channels using the Humax remote. Any ideas, seems an odd one?
