Humax HDR- Fox T2 500gb Freeview Recorder.
Discussion in 'Digital TV & Video Players & Recorders' started by c h f, Sep 21, 2018.
  1. c h f
    c h f
    Sep 1, 2007
    275
    LIVERPOOL
    +7
    Hi guys I have just purchased a used Humax and it has come with an aftermarket RM-Series® Replacement Remote Control . now it all seems to work well but there are no instructions with, what I need to know is after I have selected to pre record my programs ,how do I turn on "STANDBY MODE " ???? cheers in advance
  2. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,573
    Oxford
    +1,328
  3. c h f
    c h f
    Sep 1, 2007
    275
    LIVERPOOL
    +7
    Thanks but I have the manual for the PVR its the aftermarket remote I am enquiring about
  4. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,573
    Oxford
    +1,328
    I have purchased numerous RM replacement remotes and none have ever come with instructions. Hace you tried the power button to put the box in standby?
  5. c h f
    c h f
    Sep 1, 2007
    275
    LIVERPOOL
    +7
    oddly enough when I wrote this for the rirst 3 days all the power button done was turn it off completely, so I went through the 4 buttons TV,VIDEO,AUDIO, then back to PVR, and now its working as it should !!!!!!!
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,009
    Redditch
    +4,091
    Other than removing the power it's not possible to turn off a HDR-FOX-T2 completely. It has two sby modes (set from the menu). By default low power sby is enabled which uses the minimum amount of power (turns off RF loop through) and the clock. In either sby state it will wake to make a scheduled recording. Just press the power burron. if it's recording it will return to sby when any recording completes.
  7. c h f
    c h f
    Sep 1, 2007
    275
    LIVERPOOL
    +7
    yes as stated I have found that out now cheers
