Humax HDR-2000T sound problem
warmbells
I seem to have an unusual problem with the sound on this PVR. If I turn the unit on to watch something I have recorded there is no sound at all even on a programme that is live. I have to remove the power lead for about 20 seconds and plug it back in. When I switch it back on again the sound is there and there is sound on the recording. Is there any way of stopping this from happening without doing a factory reset which I have been told would probably wipe off all the recordings I have made?
Thanks,
Gerald
grahamlthompson
A factory reset will not delete your existing recordings. It will delete your recording schedule, so photograph your schedule with a digital camera first. Only a Hard Disk Format will do that. You can export recordings to a usb storage device to keep them safe on this model.
It will also reset any changes you have made to default setings.
Off the cuff - Box volume, forward and reverse skip setting times.
