Humax HDR 1000s Hard Drive Failure - Help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Paul97, Oct 6, 2017.
  1. Paul97
    Paul97
    Jan 20, 2004
    655
    Hartlepool
    +24
    I think my Humax 1000s hard drive is failing and need advice on a new replacement hard drive, can anyone please help.
    TIA
    Paul
  2. Nerox
    Nerox
    Oct 8, 2006
    504
    Basingstoke
    +53
    Any of the main brands of hdd are good, seagate, maxtor , Toshiba etc
  3. Paul97
    Paul97
    Jan 20, 2004
    655
    Hartlepool
    +24
    I watched a video on YouTube on how to replace the hard drive and it recommends a hard drive for video? Would any hard drive do?
    Many thanks for the reply [emoji137]
  4. Nerox
    Nerox
    Oct 8, 2006
    504
    Basingstoke
    +53
    Standard hard drives are designed for standard home PC usage, enterprise or nas drives are usually longer lasting and designed for 24hr usage, for a TV recorder I would have thought that a standard PC type drive would be fine, you can imagine the original was the very cheapest they could get
  5. TJT1
    TJT1
    Jul 29, 2011
    4,790
    East Sussex, UK
    +1,127
    Replacing a HDD on a 'think' is not a good idea.
    Just what makes you think the HDD is failing anyway?
    Have you tried a format? You will lose all your recordings, but will anyway if the HDD fails completely. Although it is not unknown for HDDs to fail in HDRs, it is not a very common occurrence, and there are ways of checking it before consigning it to the bin.
    The safest way of getting the right replacement is to open it up and get the type from the old HDD and then look for a more recent equivalent.
    It is deffo not the best idea to put a PC HDD into a video recorder (It will work though). Use a video optimised HDD. Any difference in price is only pennies anyway. What size HDD do you want to fit?
  6. garryboy
    garryboy
    Oct 19, 2009
    503
    63
    +308
    Make sure you buy 5700rpm drive. They are quieter and better for set top boxes.
  7. Paul97
    Paul97
    Jan 20, 2004
    655
    Hartlepool
    +24
    Thanks for all the replies guys :smashin:, I think the drive is failing because on numerous occasions when we try to watch a recording it just stops and none of the buttons work on the remote or the actual unit and we have to uplug the power supply and reboot.
    How to I search for a "video optimised HDD"?
  8. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,980
    Perchede 32460
    +455
    "Hard drive av ce" should find some.
    I would also suggest a reformat before you buy.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  9. TJT1
    TJT1
    Jul 29, 2011
    4,790
    East Sussex, UK
    +1,127
    ST2000VM003 or ST1000VM003 are the sort of thing.
    Have read of THIS
    Others might suggest WD drives.
    There is a wealth of knowledge about things Humax HERE
  10. Paul97
    Paul97
    Jan 20, 2004
    655
    Hartlepool
    +24
    Thanks guys, will look into all your suggestions, really appreciate it.
  11. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    See here....
    Hard drive issues « My Humax Forum
    Its a long thread, but skip to the last few pages and it becomes apparent that the 1000s has a common issue with a certain resistor failing on the hard drive contoller.
    That being the case, replacing the hard drive is not going to fix your issue.
  12. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,980
    Perchede 32460
    +455
    True, However the symptoms of the resister issue are that the unit is unable to detect the hard disk.
  13. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    Thats the end point...up until it blows you get flaky operation, missed and failed recordings etc. then one day...no hard drive and it wont come back.
    Ive had mine replaced for the issue very recently.
  14. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,579
    Redditch
    +4,193
