Humax Freeview - no sound on Panasonic
Discussion in 'Digital TV & Video Players & Recorders' started by rickus0, May 29, 2015.
Tags:
  1. rickus0
    rickus0
    Jun 19, 2011
    5
    Have just bought a Humax HDR-2000T 1TB WD for my learning disabled son. I got it working fine on an LG TV but could not get the sound to work on my son's Panasonic (I think it is a TX-32LMD70 - can check that out when I next see him) - the picture is fine.
    Have used the same HDMI lead on both TVs and tried it going into 2 different slots on the tv.
    Humax tell me that the problem may be solved by turning off Viera Link on the TV. Can that be done and might it work?
    Panasonic told me it will not work as Viera Link is not in use when connecting to a Humax.
    Has anyone else had this problem and managed to fix it?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,342
    Redditch
    +4,143
    Yes you can turn off viera-link (On my Panasonic it's Menu - Setup - Viera Link Settings). If it doesn't work, next thing to try is turn up the volume on the Humax remote control. Lastly in the Humax TV settings Menu - Settings - Preferences - Audio - Digital Audio Output - Stereo
  3. rickus0
    rickus0
    Jun 19, 2011
    5
    Thank you Graham
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,342
    Redditch
    +4,143
    You are welcome, did you get your audio back ? If so what worked ?
  5. rickus0
    rickus0
    Jun 19, 2011
    5
    Visited my son yesterday. I found a Viera setting that could not be changed but did manage to turn it off using another setting deeper in the menus. However the sound still did not come through even after turning both the TV and the Humax off and on.
    I took up some spare leads with me and connected the red and white audio leads. The sound then came through - so will leave things like that.
    Thank you for your help.
  6. Charlie Read
    Charlie Read
    Aug 31, 2018
    3
    Hampshire
    Seems not alone but no sound with a Panasonic TX - 43FX650B played through Humax HDR- FOXT2.Help.
  7. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,342
    Redditch
    +4,143
    In the HDR-FOX-T2 TV settings change digital audio out to Stereo. Then turn up the box volume using the HDR-FOX-T2 remote control.
  8. RobTi
    RobTi
    Dec 11, 2003
    2,593
    Hamilton
    +151
    Have to use a optical lead with my Panasonic
