humax freesat digital audio connection
brawson
can anyone help.
just connected my humax freesat box to my a/v amp via optical link,but found that i can't control t.v volume with humax remote,as i could when t.v was connected directly to a/v amp via audio cable.
i can only now control t.v volume with a/v amp remote.
logiciel
Outstanding Member
Why do you want to control the TV volume when you're using the amplifier for audio?
grahamlthompson
In memoriam
can anyone help.
The Humax remote is not clever enough to have punch through to control the amplifier volume in the PVR mode. Short of a something like a logitech harmony you need to programme the hdr remote to control your amp using the other device buttons
brawson
see your point.
i have t.v volume set to min.,so not using t.v speakers.so before was controlling t.v volume through amp via humax remote.
now with optical link connected between humax box and amp,i can't do this.am i missing a setting or is this how it is.
trying to avoid having to use 2 remote's.
grahamlthompson
In memoriam
see your point.
Originally the hdr let you control the volume over s/pdif but only for SD channels using MP2 sound which the box converts to PCM. It's not possible to control the volume of Dolby Digital used by the HD channels as it's encoded in the data stream. Your amp has to alter the volume after the data is decoded into either stereo or 5.1 analogue. Humax took the SD volume control off in the latest firmwares. This is a right pain as you used to be able set up the SD volume so that there was little volume difference between HD and SD channels
believeinbutter
can anyone help.
Same happens to me...same set-up.
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
