Humax Foxsat retuning Olymics
JCKnowles
If it ain't broke don't fix it....but
..what, with all this this extra stuff on the red button, I thought I'd re-tune all the channels. Did factory re-set, then tried to re-tune. Invalid postcode.
No channels. Nothing.
I've tried lots of 'fixes'. Nothing seems to work.
Unlikely to be a hardware problem, as everything was working perfectly one minute.
Any ideas?
grahamlthompson
In memoriam
Using manual tune what signal strength and quality do you get on 11427 H ? (might say 11426 or 11428)
JCKnowles
Graham, thanks for your response.
Using manual tune on transponder 11428H 27500A (Network search-disable/Scrambled type-FTA/Channel type-All),
No channels are found and Strength and quality are both 0%
I guess you're thinking about connections etc - but isn't it strange that it all went pear shaped after an attempt to retune?
grahamlthompson
In memoriam
If you lose access to this transponder after a first install then while the box appears to work OK because the epg continues to refresh from data transmitted with the channels you still have. Pressing guide would have given you a problem because this contacts the home transponder to download a new one. After a reset without access you can't set up your local channels. The dish may have moved slightly or perhaps water has got into the coax cables.
JCKnowles
Graham,
Thanks again for the info. I cut the cables and re-did the connectors, just in case it was a connection problem - but to no avail. Time to get the ladder out......
hector13
same here in rayleigh essex - lost all channels while trying to retune.invalid postcode etc.Have paid out £65 in service charges already - box taken to shop and worked ok there.Was fine until went to retune for olympic channels and now back to where i started.Now expecting another dish man out :confused:
