lauraeva
I'm fed up of procastinating and have decided to go for the Foxsat PVR as a) I can get HD right now, b) I perceive Freesat SD to be better than Freeview SD on my Sony TV which has both tuners. But this depends on the answer to my question.
Problem is that I only have a single working LNB outlet in my living room, the other has a discontinuity in its wiring (which was installed into the fabric of the 3 storey house when it was built - not easy to fix).
If I connect the satellite cable to LBN-1(IN) and connect LBN-1(OUT) to the TV what functionallity will I get ?
I'm thinking that when the PVR is in standby I will be able to use the TV's own Freesat tuner as normal.
And that I would only be able to record a single channel at a time even if channels were on different MUXs ?
What happens if the PVR starts recording while I'm using the loopthrough to watch Freesat TV ?
Is what I'm proposing a no-no ? Could I even damage the equipment ?
Actually the more I think about this the more I think that my supposition that the LBN IN/OUT loopthrough is like an aerial feedthrough is wrong ...
