Humax Foxsat HDR
Discussion in 'Satellite TV, Sky TV & FreeSat' started by The Bard cv37, Jul 16, 2015.
Tags:
  1. The Bard cv37
    The Bard cv37
    Jun 22, 2009
    199
    warwickshire
    +17
    As per the subject line, I have a Humax Foxsat HDR with Raydons custom firmware.
    Please can some one guide me as to why I have to constantly view the epg, to cure the ***false pretense*** of their only being one tuner. Again, unless I do this I can't record one channel while I watch another.
    Thanks in advanse
  2. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,990
    Perchede 32460
    +456
    I suggest you make a note of your schedule and try a factory reset. Watch carefully for the on screen message that confirms 2 working tuners.
    Check channel 999 before you do this to ensure you have a good signal from the home transponder.
    Do you use the custom firmware channel editor?
  3. The Bard cv37
    The Bard cv37
    Jun 22, 2009
    199
    warwickshire
    +17
    Repassac--Many thanks for your idea, though I have found the service menu and changed a setting
  4. TJT1
    TJT1
    Jul 29, 2011
    4,825
    East Sussex, UK
    +1,139
    Do you not have to reboot after setting from 1 to 2 cables?
  5. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    I think the OP is referring to the custom firmware settings page that has an option to specify how many cables are connected (used to identify simple recording clashes). In regards to the actual box there is two ways
    1 Factory Reset
    2 Change the connection mode in the hidden menu.
  6. The Bard cv37
    The Bard cv37
    Jun 22, 2009
    199
    warwickshire
    +17
    Gents--
    Ro answer the questions, I have not not a restart, but would try it next.
    I have checked hand set menu, then diacnostics which shows 2 satelite feeds.
    The service menu--- I am sirprised, how ever it is reached by pressing the coloured keys in a certain order. Graham, looks about right
  7. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,990
    Perchede 32460
    +456
  8. Vin Blanc
    Vin Blanc
    Feb 18, 2011
    371
    New Milton, Hants
    +57
    I recently changed a Humax Foxsat HDR from single cable to two cable feed.
    I simply carried out "Factory Reset" and followed the instructions through.
    BTW, before starting, I made a note of all planned recordings and re- entered them after the reset. Previous recordings are not lost but your preferred timer settings will need to be reset.
    Vin Blanc
  9. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    Absolutely right if i remember correctly.
    Afaik the Custom Firmware does not have the capabilty to check the actual connection mode, It's a user setting in the CF settings. If incorrectly set to single cable mode setting two recordings at the same time reports a clash (even though it's actually possible).
    If you set the same actually on the box (and it is correctly configured in two cable mode), there is no issue.
    The CF now has the capability to access the actual installed freesat transponder data from your box In theory given if it knows the correct number of cables it should be possible to correctly check two scheduled recordings and a 3rd watch recording is possible (Emulating the Excel Automatic application I wrote a long time ago).
    Whether it's worth building this degree of sophistication into the CF, I leave to the real experts like Raydon and AF123.
  10. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    The same happens if you change the connection mode via the hidden menu ). This is really designed to accomodate different satellites when you have access to different orbital points for freesat mode using diseqc or usals motorised dishes).
