paperwhite
Hello everyone, new member here (with probaby an old queston.) Purchased the foxsat hdr, think its a great little box, sadly it does have its perculiarities. It will loose channels when its recording or SOMETIMES it wont record 2 channels at once (even though it has a twin tuner and i do have two cables connected to the box from the LNB) I've been trying to follow the upgrade instructions for my foxsat hdr from the Humax website. Downloaded (Foxsat HDR-upgrade_hdf) on to a 1gb memory stick as instructed, plugged into the sat box, turned on sat box, kept finger on 'on' button for the recommended 30 seconds, was expecting to see the download progress on the screen but it was if there was no memory stick plugged in. im sure it can be done but i dont know if the problem is with the box itself or am I overlooking something??? Any suggestions would be very helpful. thanks
