I have managed to copy Freesat HD files to an attached USB Ext3 hard drive. I didn't need to go through the non-Freesat route - I just copied them from Freesat. I can play the file on my Windows 7 PC using Windows Media Player, but although I can see the video, I can't hear the sound.
MediaInfo gives the following information:
General
Complete name : K:\Heir Hunters_20110309_0954.ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 148 MiB
Duration : 2mn 22s
Overall bit rate : 8 701 Kbps
Video
Menu ID : 6941 (0x1B1D)
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 2mn 22s
Bit rate : 7 896 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.203
Stream size : 134 MiB (91%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 6
Duration : 2mn 22s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -1s 27ms
Stream size : 3.26 MiB (2%)
Language : English
Any ideas on how to get the sound working on the PC? I notice it is AC-3 rather than the MPEG Audio of the SD files - which do play properly on the PC.
I dropped the HD file into Corel VideoStudio and saved it out as an AVC HD file and that does play the sound as well as the video. The converted file is also AC-3 - so why won't the origonal sound play?
My experiments were done with small recorded files, which were easy to transfer. I did try transfering an episode of Eastenders in HD and, although it did copy, the Faxsat crashed and rebooted after about 26 mins were copied - 1.54GB. The incomplete HD file does play, but no sound again, as before.
Any suggestions welcomed.
Ray D
