Humax - Foxsat HDR 500GB
Discussion in 'Satellite TV, Sky TV & FreeSat' started by vinylman, Mar 8, 2013.
Tags:
  1. vinylman
    vinylman
    Jan 12, 2013
    331
    Surrey
    +21
    Can anyone help? If I want to record two programmes on an evening and they are on different channels (obviously not at the same time as that would be ridiculous) - I find that I have to ensure the Freesat box is switched to the correct channel for the first programme in advance and also, very annoyingly, I find that when it is time for the second programme (and I'm fast asleep) it doesn't change channel automatically and, hence, I end up without the recording! Is there a way around this?
    VM
  2. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    If you have two connections to the machine from the satellite dish then it will record any two channels at any time, including the same time.
    With only one you specify the fact and it switches automatically from one channel to the other.
  3. vinylman
    vinylman
    Jan 12, 2013
    331
    Surrey
    +21
    Thanks. I only have one connection. How do I specify that fact?
  4. logiciel
    logiciel
    Feb 2, 2008
    53,117
    UK
    +5,765
    There should be an option in the menu, like there is in a Sky PVR's.
    You can connect the Satellite Out socket to the second In socket and get a limited range of two channels at once.
  5. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,966
    Perchede 32460
    +449
    It would have detected that during the install. It would assume that you have installed the loop from LNB1 OUT to LNB2 IN (which will enable the second tuner) and act as if it has two tuners but only 1 LNB.
    See the installation diagrams and instructions in the manual,
    A factory reset will cause redetection.
  6. caldirun
    caldirun
    Mar 18, 2007
    441
    Sheffield area
    +20
    If the Foxsat is in standby it should do what you require, if it is being watched it should report a conflict, could be a faulty unit!
