Humax Foxsat HDR 500 Question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by JaceyBoy, Jan 11, 2012.
Tags:
  1. JaceyBoy
    JaceyBoy
    Oct 12, 2006
    222
    Ferndown
    +3
    Hi Guys,
    Ive just ditched Sky and it ends on 7th Feb, im going to buy a Humax Foxsat HDR 500 box as its a good box and believe its the only box which you can stream around the house.
    We currently have the Sky going into 5 rooms via the Magic Eye, my question is I know the Humax Box can do this but what is the equipment that I need to get which will power the Magic Eyes?
  2. bspks
    bspks
    Aug 18, 2004
    27
    I'm just thinking of doing the same myself, but I was going to get the equipment first before I cancel Sky.
    The Tri-Ax Tri-Link seems to be the kit we need, you can use the existing eyes and cabling with it.
    Link here: www.triax.co.uk/upload/trilink_web.pdf
  3. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    The "magic eyes" are only for getting the IR control back to the receiver.
    The first thing is to get the satellite channel sent from the receiver to the extension TVs.
    With a Sky machine you do that from its RF2 Out socket, but Freesat machines don't have those.
    You can get "modulators" that connect by Scart to the machine to provide the aerial-type socket:
    RF MODULATOR - CONVERT SCART PHONO TO TV AERIAL RF COAX.
  4. JaceyBoy
    JaceyBoy
    Oct 12, 2006
    222
    Ferndown
    +3
    I thought the Humax did indeed have the RF2 out?
  5. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,943
    Perchede 32460
    +446
    No freesat box has a RF out. Why would a digital box want to go back to analogue (so the spec authors thought).
  6. JaceyBoy
    JaceyBoy
    Oct 12, 2006
    222
    Ferndown
    +3
    Oh didn't know that, so why don't I buy a Samsung one?, they look good?
  7. bspks
    bspks
    Aug 18, 2004
    27
    The Tri-Link device I posted about above, as I understand it, features a modulator with 2 RF outputs, one of which will power the magic eyes, exactly the same principle as that built into the Sky boxes.
    From what I can understand, you plug a lead from a Scart socket on the Foxsat into the Scart in on the Tri-Link unit. If you had something already in the Foxsat Scart then you plug that into the Scart out on the Tri-Link.
    You then connect your aerial (if you use one) to the RF in on the Tri-Link and you have 2 outputs to use as with Sky.
    Only one of these provides the 9V to supply magic eyes and powered splitters, but that's also the same as Sky.
    You then connect the power unit to the Tri-Link and plug it in.
    At least, as I'm about to order one to go with the new Foxsat I'm also about to order so that I can ditch Sky, I hope that's how it will work.
  8. JaceyBoy
    JaceyBoy
    Oct 12, 2006
    222
    Ferndown
    +3
    We I hope it works that way, when are you going to have it fitted?
  9. JaceyBoy
    JaceyBoy
    Oct 12, 2006
    222
    Ferndown
    +3
  10. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    Yes, checking through the specification, I see that it includes the modulator, which it describes oddly as "fully agile".:confused:
    If you get one I'd be interested to know what that means - and of course how much it all costs.;)
  11. nowster
    nowster
    Apr 6, 2011
    287
    43
    Manchester
    +114
    It'll mean that it can be tuned to output on any UHF channel from 21 to 68 (maybe 69).
  12. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    That sounds like a good guess as to what it means.:clap:
  13. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,194
    Redditch
    +4,111
    It's a correct guess :D
    http://www.scatmag.com/technical/modulator.pdf
  14. logiciel
    logiciel
    Feb 2, 2008
    53,021
    UK
    +5,729
    That's a new one for the OED!
  15. bspks
    bspks
    Aug 18, 2004
    27
    Got the Foxsat now, just need the Tri-Link and an extra remote for the bedroom.
