Humax F2 Fox T, Will The Scart Sockets Act As A Pass Through.
jedi master
Thinking of getting a Humax F2 Fox T, just want to know does it act as a pass through aswell ??
i.e. if i have one scart going from the a scart switcher box that has my consoles in to the VCR socket on the F2 and then a scart from the F2 to the TV as standard when i turn a console on would the TV still auto switch and the F2 pass through the cosoles. If so is the pass through fully RGB ?
Fred John Dough
The vcr socket on the F2 fox does NOT support RGB only Composite or S-Video and it is output only, you can feed a RGB signal from the F2 TV socket to your scart switchbox and then to your TV or as I have 2 receivers DVB-T and DVB-S and 2 DVD recorders plus game console to TV via a blue delta auto switch box which sees the RGB signal of the unit that is on and Auto. switches through to the TV , brilliant unit.:D :D
jedi master
The reason why i asked was because my sky box acts as a pass through even though the vcr socket is a output. But anyways if it does'nt support RGB then thats no good , guess i'll have to replace my scart switching box for a new one that can have more inputs.
J
jafro
Hello,
Posting on behalf of my father, who's been looking into RGB loopthrough and has experience with some Humax boxes:
I am pretty sure the Humax F2 Fox T does provide RGB loop through from VCR to TV.
But I think you'll also find that the CVBS status does not operate correctly, which may result in incorrect switching on TV and/or incorrect aspect ratio display. (F2 Fox T VCR out is CVBS or S-video).
Hope this helps.
James (on behalf of Gordon)
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
