Humax DV1000T
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by BIGDAZ, Nov 4, 2004.
  1. BIGDAZ
    BIGDAZ
    Sep 7, 2004
    7
    Here's a hack for the Humax DV1000T
    1. Switch to DVD mode
    2. Press 'Menu' Key on the Remote control
    3. Go to the Parental Control Menu (You will be prompted to enter your
    password)
    4. Press number '4' key
    5. Press the following coloured buttons: Red--> Green--> Yellow-->Blue -
    6. A small box will appear to the R/H of 'Parental Control header' with a number in it ( mine was '0' but it wasn't multi region)
    7. Then press key '9'-'6'-'3'-'x' - ( I used '0')
    a. x: region code
    b. 0: all free
    c. 1~8: region code
    8. Then press the standby button.
    9. switch unit back on and use above method to show region and now it should have an 'A' in it. (all regions I suppose)
    Job done. I hope this of help to somebody
