Humax component output.
Een
I have an old panasonic TH42PW4 plasma with component input. I was thinking about getting the Humax HD freesat box but have heard that the component output is sd only.
Does anyone know if this is true.
dan1979
I have just tested this for you.
720p and 1080i over component works fine and even better it's outputting component and HDMI at the same time :thumbsup:
technogran
I would be interested to know whether or not the picture is sharper over the component connection or the HDMI connection or is there no difference?
TG:confused:
technogran
Thanks for that, I may try the component connection then, the Humax HDMI leaves a lot to be desired in my view and is disappointing. Mind you I did own the Humax 9200t and I always found that picture to be soft when compared to other PVR's. Must be a Hummy thing!
TG:smashin:
Een
Looks like i'll be getting one of these after all then.
Thanks for the replies guys. :thumbsup:
Mr.Glass
Do you know if it will O/P SD over component and HD over HDMI at the same time?
I want to make two connection to my tv and have different settings for each!
I would like the TV to de-interlace and upscale the SD channels via component but would like the HD go straight into a HDMI port on the TV.
I have a feeling I could use HDMI and Scart for this but would prefer to use component instead of scart for the SD if possible?
