Humax changeover
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Padrick, Jun 9, 2009.
Tags:
  1. Padrick
    Padrick
    Feb 5, 2009
    11
    I have just changed from Sky+ to a Humax freesat+ 320Gb hdd. When I reconnected my twin cables from my old LNB and tuned Humax box in I do not seem to be able to record 2 channels at once ! anbody got any ideas?:lease:
  2. son_t
    son_t
    Jan 12, 2006
    1,524
    +176
    By connecting one cable at a time, find out which one of your feeds is not working... and fix the cable..?
    Also make sure you connect both cables to the IN and not one to the IN and the other to the OUT (there are 3 connectors on the HDR).
  3. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,450
    Redditch
    +4,161
    If the connections are wrong (2 outers are right ones) after correcting them you will need a factory reset to recognise the new connection.
  4. Padrick
    Padrick
    Feb 5, 2009
    11
    Thanks guys, all sorted -- changed over cables checked tightness and did a system reset and all is now working fine I can record 2 channels at once.:clap::smashin:
  5. alan47
    alan47
    May 31, 2009
    29
    3
    I had a similar problem but was trying to record both from epg. I can record 1 from epg and the second live from the channel selected.
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,450
    Redditch
    +4,161
  7. Padrick
    Padrick
    Feb 5, 2009
    11
    All sorted now thanks:clap::smashin:
