Good Morning
Having just purchased a second hand Humax 9200T PVR I am having problems getting it to function correctly to operate with a Samsung LE32 B450 C4W
ie: I connected the Humax to the tv aerial input socket, then the loop to the television, switched on the Humax and it went through its motions similar to a 'boot-up' then the tv screen said 'weak or no signal', then
I then switched off the Humax, then pulled out the tv aerial, switched the Humax back on, when the password --- --- --- --- appeared I tried putting in 0000 with the remote, but nothing happened, tv said that 'weak or no signal'
Note The tv works fine with the aerial plugged in.
The remote works ok because I tested it with our own Humax 9200T remote control.
I am aware that being a second hand set, it will be looking for the antenna that it was originally set to, so I would like to return it to factory settings again, in order to reinstall to my local area, BH25, but with no signal being passed from the Humax to the tv makes this impossible.
Being in my 70s I am not the 'sharpest knife in the drawer' but would appretiate a little help in this matter.
regards
BobUK
regards
BobUK
