OMG frozen and stuck 9150s becoming common already (well second one today).My mother's new 9150 is stuck on ITV1. She's switched it off at the back and unplugged it but it's still stuck. Any ideas on how to fix it?
The 9300 in the other thread freezes on ITV1 and E4. This is what I put there:I went over to my mother's to night to have a look at the 9150. If you switch it off and back on again you can change to another channel and it works fine. If you leave it on or go back to ITV1 for more than a minute it sticks again.
This problem has happened again. Has anyone else had the same problem?
Bri
What software version and system identifier does diagnostics report ?
Firstly, remove the aerial from the PVR and then power it on.
Access your MENU>INSTALLATION>DEFAULT SETTING>YES (your password is '[email protected] when required)
The unit will now turn itself off and on again.
Once the machine turns off you will need to reconnect the aerial.
This will reset your box and rescan the channels, once this is finished, make sure to SAVE the results, and this will solve your problem.
I don't know as I don't live near my mother. I found what worked last time in the other thread.
I've just tried to tell her over the phone what to do but she couldn't follow it. She only got out of hospital yesterday and I'll have to go over when I can. It'd be interesting to know if any one else has had this problem today and if they resolved it using this method before I go over.
Last time the problem was confined to the Pontop Pike transmitter in this area.
Bri
There was a major problem the other day when Freeview made a change to the epg. Lots of people with out of date software suffered the symptoms you describe. Most had not got the latest software because their boxes were not left in sby overnight.
