Humax 8000T80GB manual recording
Discussion in 'Digital TV & Video Players & Recorders' started by Cablechap, Jan 6, 2005.
Tags:
  1. Cablechap
    Cablechap
    Oct 22, 2004
    142
    +6
    Hi All,
    I've had one of these for a couple of weeks now and am already aware of the stereo sound output bug. However, I believe there may be another one unless it is a standard feature.
    If I record manually, the box switches itself off record after 2 hours even if there is loads of GBs of space left. Timed recordings over 2 hours are fine.
    Anyone else had this problem?
    Cablechap
  2. bennema
    bennema
    Feb 8, 2007
    44
    +7
    I have a 8000T (40gb) and yes sometimes it records for 119 minutes when pressing record, and yet other times it just uses all the disc space if left recording all night. I don't know why as the manual makes no mention of this.
    Also I have no problem with length of programmed recordings.
  3. bainsyboy
    bainsyboy
    Jul 27, 2006
    151
    +16
    Im sure if you just press record once the unit records for two hrs, if you press the record button again it will say 1hr59mins keep pressing record untill you see the time you want, im sure if you press it to record 3hrs+ it will record till the hard disk is full up
  4. smallesttrade
    smallesttrade
    Jan 19, 2007
    1,526
    48
    +33
    I know a bit off topic but whats the latest update for this box?
    cheers
