Humax 8000T
Discussion in 'Digital TV & Video Players & Recorders' started by johneccles, Feb 5, 2005.
Tags:
  1. johneccles
    johneccles
    When I try to record from Humax either live or recorded programme to my Philips DVDR I get a message "copy protected" !! It used to work but now it doesn't. I have no problem recording from cable Its only happens when I use the Humax. Any ideas please. John fron Preston
  2. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    It was a known issue with the Humax that they forgot to switch off the copy protect flag that is sent out with the video signal. This makes DVD recorders behave in the way that yours does. I thought that this had been fixed on later firmware updates.
  3. johneccles
    johneccles
    Thanks for your reply, I have checked the update which is October 2003. What I cant understand is that it used to record but now it doesn't!! I think I will reinstall it and see if that helps. Unless you have any more ideas? Cheers
  4. johneccles
    johneccles
    I have updated the device and it has the the lateset update (Oct 2003). What I cant understand it that it used to work OK but now it doesn't!!. I think I might reinistall it all over again, unless you have any other ideas? Thanks John
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    The latest update is dated 30th Sept 2004. Yours is almost a year earlier.
