Humax 8000T Scart lead
Discussion in 'Digital TV & Video Players & Recorders' started by ThirdWay, May 5, 2005.
Tags:
  1. ThirdWay
    ThirdWay
    Just bought a Humax 8000T PVR. I'm very pleased with the functionality, however....
    Using the supplied scart lead to connect to my Philips TV I get a very noisy picture. When I swap to another scart lead the picture is much better.
    Is the supplied lead poor or unshielded?
    Another funny: I'm connecting the Humax to my TV's AV2 scart socket which is svideo/composite (the TV's AV1 is RGB but I've connected my DVD to this).
    When I set the Humax AV1 scart socket to svideo the picture comes out black and white, but is OK when I set it to RGB! This strangeness occurs with either scart lead.
    Any thoughts? Cheers.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    get a decent scart lead and read your TV manual for using the AV2 with S-video, some times a TV with a composite scart does funny things when you feed it S-video. (RGB uses composite signal as Sync so composite signal is contained in the rGB feed)
  3. ThirdWay
    ThirdWay
    Have now fixed the black & white problem:
    I press the AV button until I get EXT2 - press it again then I get S-Video2 (on EXT2 scart) in glorious colour!
    Will later re-check with the Humax scart lead...
