Humax 8000 clicking noises!
Discussion in 'Digital TV & Video Players & Recorders' started by Johnster, Jun 6, 2005.
Tags:
  1. Johnster
    Johnster
    May 17, 2005
    7
    Just bought a Humax pvr8000 (80gb). All appears to work fine but when you 1st switch it on (from standby as well) it makes a clicking noise for 2 or 3 minutes. Changing channels can speed up or slow down the clicking.
    Is this normal Humax behaviour, i can't find anyone else with a Humax to ask?
    If not normal i will send back for a replacement.
    Many thanks,
    John
  2. thudspud
    thudspud
    Mar 28, 2002
    2,279
    Sheffield
    +89
    Mine did it when I first got it and it would go away after a few minutes, when I swapped to a 200GB HD the clicking went away.
  3. Crocodile
    Crocodile
    Nov 4, 2002
    15,527
    +4,718
    The time to worry is when it STOPS clicking.... :rolleyes:
  4. Johnster
    Johnster
    May 17, 2005
    7
    Thanks for the info thudspud
    Does that mean Humax use noisy/cheap hard drives? Are they standard IDE drives or do i need a particular speed read/write access times 5400/7200rpm ?
    Not that I wasn't intending to buy a brand new piece of kit and then change all the components!
  5. Ikki
    Ikki
    Feb 23, 2004
    1,173
    2
    67
    Lancs
    +97
    They are standard PATA IDE hard disks and the speed is not important. What is important is that you use a model that others have had success with as some models and brands do not work correctly.
    A 'how to' thread is available here:
    How to upgrade your Humax PVR8000T hard disk
