Humax 5400 Y U V Output
Discussion in 'Satellite TV, Sky TV & FreeSat' started by patmyhead, Dec 31, 2003.
  1. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    I have this humax which according to the onscreen menue can output RGB S video & Y U V
    problim is i carnt get a picture when Y U V is sellected ,i used a Squart scart to phono with the yellow sinc lead to the compositive input on my amp .with the red blue green to their normal input slots result nought:confused:
    Any ideas?
    P@T
  2. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    You will need a scart to componant lead with either 5 phonos (2 red, one white, one green and one blue) or 3 phonos (red, green and blue), and then output YUV from the box and connect the phonos to your amp, you cannot use a normal composite scart to 3 phono leads (yellow, red and white)
    Rich
  3. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    Thanks for reply Rich
    the scart is a qed squart which is scart one end then red labled rv (pr) green labled gy blue labled b/u (pb) + yellow .the yellow is labled rgb sinc all these ends say input
    2 other leads black & white for audio
    YUV is selected on amp
