Humax 5300 dead??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by ramjam55, Oct 31, 2004.
  1. ramjam55
    ramjam55
    Aug 6, 2003
    1,186
    Durham
    +27
    I've got a Humax 5300 digi box and it's just suddenly decided not to work :( . I've powered it down and back up but the fron panel is not showing the power led and does nothing. There is power going to it as the optical out on the back glows red. has anyone had this problem and know of a solution or is it a dead box and I'll have to buy another ?
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    Power supply fault quite likely there, mate.
    Not a massive repair for a decent engineer. About £50.
    A. Dork
  3. ramjam55
    ramjam55
    Aug 6, 2003
    1,186
    Durham
    +27
    Think I'll take it along to a repair shop and see what they say. Have to way up the cost of a repair vs the costs of a new box from the forums or ebay.
  4. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    i had the same fault with the 5400
    got a new power unit from pulsat ,fitted it myself dead easy if i can do it anyone can
    Pat
  5. ramjam55
    ramjam55
    Aug 6, 2003
    1,186
    Durham
    +27
    Can you pass the details on please. I have found that the power supply is the cause as I can see that a resistor has burned out :(
    Since I don't kow it's value (does anyone ???) I can't replace it.
  6. patmyhead
    patmyhead
    Feb 11, 2002
    590
    I o M
    pulsat.co.uk is where i got mine cart remember the price i paid think it was about £30/£40
    it comes with instructions for fitting
    do a search you may find it cheaper
    good luck
    Pat
  7. ramjam55
    ramjam55
    Aug 6, 2003
    1,186
    Durham
    +27
    Cheers. I've found a place that does a repair kit for £9 so may try that even though it'll prob only consist of a resistor and a diode. I'll call pulsat as well and see what the cost of a new board is as it may be better to go for that and know its a new supply.
