Humax 4 dashes
Discussion in 'Digital TV & Video Players & Recorders' started by Cablechap, Apr 25, 2005.
Tags:
  1. Cablechap
    Cablechap
    Oct 22, 2004
    142
    +6
    Since the last couple of software updates my 8000T80 seems to have developed a fault.
    Occasionally, when turned on or timer set, the box does not initiate properly, getting stuck with 4 dashes ---- on the display. Turning the off the switch at the back has made no difference. This is really only a problem for timed recordings because obviously nothing is going to get recorded.
    Anybody had this problem (since update) or is it just faulty?
    Any ideas welcome.
    Cablechap
  2. Crispin
    Crispin
    Nov 21, 2004
    181
    +8
    Yes - I get this too.
    It happens very occasionally, perhaps every 10 or so activations.
    What happens is that the HDD goes though its usual initialisation. I *think* it then pauses at 80% and then goes into the boot Application/Games re-load (which should normally only occur on a software update).
    After this has finished the machine displays '----' and stops.
    As you say, if this happened during a timed recording then presumably the recording would not occur.
    The other consequence of this happening is the EPG is wiped.
    Scheduled and recorded programs are unaffected.
    I had a theory that this might occur if the machine were switched off too quickly whilst it was still accessing the HDD - but experiments proved this not to be so.
    I cannot determine any pattern to these occurrences.
    Regards,
    Crispin.
  3. Crispin
    Crispin
    Nov 21, 2004
    181
    +8
    Humax's advice was to re-initialise the factory settings.
    I did this and so far the problem has not re-surfaced.
  4. Cablechap
    Cablechap
    Oct 22, 2004
    142
    +6
    Crispin
    Sorry for such a late response.
    It does seem to happen every 10 start ups or so. In fact I got about 10 recordings achieved whilst on holiday before it failed again.
    Thanks for the advice, I will give that a go and see if clears it.
    Cablechap
