Humax 26" Widescreen HD Ready LCD TV Twin DTT Tuners & 40Gb Hard Drive
Discussion in 'LCD & LED LCD TVs Forum' started by Gordon D, Oct 29, 2005.
Tags:
  1. Gordon D
    Gordon D
    Oct 1, 2005
    140
    Hertfordshire
    +5
    Don't know if anyone is interested but the QVC TSV is a...
    £999.48
    UK Postage & Packaging £18.00
    Save! Buy two or more & save on postage and packaging
    Easy Pay 3 monthly Installments of £333.16, plus Postage & Packaging.
    Features and specifications:
    * 26" LCD screen
    * Resolution: 1366 by 768 pixel
    * Progressive Scan
    * Twin Freeview Digital Tuner and 1 Analogue Tuner ( Terrestrial)
    * Digital 2 Tuner PVR ( Personal Video Recorder Function)
    * 40 GB hard drive recorder and player (allows you to record 44 hours of Programming without the need for Tape or DVD)
    * Pause live TV function on 40GD
    * 1000: 1 contrast ratio
    * 500cd/m2 brightness
    * Less than 16 ms response time
    * Viewing angle: 170 Degrees
    * Nicam Stereo sound
    * Sound output: 2 by 7 watts
    * PC input
    * DVI connection
    * HDCP ( High Bandwidth Digital Content Protection )
    * Picture in Picture functionality
    * Parental control
    * 120 page Teletext
    * Integrated TV stand
    * Terminals: 3 scart and 1 RF port
    * Component Input –RCA Jack
    * PC RGB Input – D Sub 15 Pin
    * PC audio input stereo jack
    * Headphone stereo jack
    * Smart card slot for top-up TV
    * USB 2.0 capability
    Accessories included :
    * User manual
    * AC power cord
    * Remote control
    Clicky for QVC
  2. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +565
    Yes i seen it last night aswell looks good seems to be a updated version of last years model as its not on http://www.humaxdigital.com/uk/ with those specs. The girl showing it off said it had a hdmi input but according to your qvc link its dvi instead lol.
    would prob give it a try if i didnt already have a lcd tv.
  3. digitalwolf
    digitalwolf
    Aug 18, 2005
    303
    Midlands
    +4
    She didn't have a clue how to drive it. She tried to show off the split screen with 2 DTT channels showing at the same time. :)
    They make me smile :)
  4. geordie458
    geordie458
    Sep 4, 2005
    17
    3
  5. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +565
    Dont forget there are 2 models of the 26"humax one with the older 1280x768 resolution screen and the new one on qvc which is 1336x768 screen and better contrast and luminance it doesnt give you the full specification on geordie458 try here : http://www.callde.co.uk/humax_lgb-26tpvr.asp
    £858 inc vat and del so be wary.
  6. Shrink
    Shrink
    Oct 9, 2004
    17
    I suspect that QVC have made a mistake with their specs. The contrast ratio, resolution and luminance are of the 32 inch model. Are you sure that there is a newer 26 inch model with these specs, Peahead? :confused:
  7. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +565
    I think you are right about that one Shrink not the first time qvc has made a mistake also the girl said that the pc resolution was running at 1280x768 which fits with the real specs are qvc trying to pull a fast one. :nono:
  8. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +565
  9. Shrink
    Shrink
    Oct 9, 2004
    17
    Hmm. The plot thickens. I think I'll ring Humax tomorrow.
  10. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    The reviews I've read of these Humax PVR TVs have usually said words to the effect of 'nice idea but shame the picture quality isn't up to scratch'. I would recommend you buy the tele from a brand who knows more about getting the TV basics right, and then hook it up to one of Humax's excellent seperate PVRs unless space is a major issue for you.
  11. coley65
    coley65
    May 27, 2005
    152
    +4
    I have the 32" version of this tv. I bought it last week from the QVC clearance shop for £750.
    After using it for a couple of days I have to say this is a very poor set due to the picture being so dark. I can have this for 30 days and if I dont like it I can return it.
    There are a lot of good things about this set like pc side of is superb pq text is razor sharp games look fantastic but like I said everething is just too dark. I would be very careful with Humax lcd. But there stbs are top notch. I would love to keep this tv if anybody has a fix for this tv I would be grateful if you could post
    Before the Humax I had the Tevion 32" which was bright and the pq was superb but using the pc side of things was rubbish (text)
    Regards Coley
    Regards Coley
  12. Bilbob
    Bilbob
    Feb 21, 2005
    4,588
    103
    Manchester
    +294
    I've got to say, if the picture is any good on this, I'll be VERY impressed, as the spec if really very good indeed.
    Oh and BTW, according to Humax, the resolution of the panel is 1366x768, and not 1280, as stated in the manual. Might have to have a trip to John Lewis to see one of these in the flesh I thinks...
  13. DaveP
    DaveP
    It has an USB port for connecting an external hard drive! That could be interesting.
    Dave
  14. coley65
    coley65
    May 27, 2005
    152
    +4
    On the 32" model you can only backup the internal hd not use as more live storage space. Does anybody know how to get into the service menu on Humax sets
