Question Humax 1100s change audio language from media files
Discussion in 'Digital TV & Video Players & Recorders' started by reddwarf4ever, Sep 5, 2018.
Tags:
  1. reddwarf4ever
    reddwarf4ever
    Aug 16, 2012
    hello
    Can’t see how to change the audio track from video played via the usb socket.....some of my video has multiple languages, hopefully there is an option..
    Also some MKV video plays audio only....I assume as MKV is a container, some video may not be compatible is that the likely reason ? Plays ok on a stand-alone media player.
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,344
    Redditch
    +4,143
    uSE tsMUXER gui TO DELETE ALL AUDIO BTRACKS APART FROM THE ONE YOU WANT AND REMUX WITH JUST THE ONE TRACK.
    tsMuxeR 2.6.12 Download - VideoHelp
  3. reddwarf4ever
    reddwarf4ever
    Aug 16, 2012
    Yes I can do this, it’s just a pain it can’t be done from the player, pity Humax can’t update this a bit with a software update
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,344
    Redditch
    +4,143
    This is also a known issue when streaming recordings from a Custom Firmware equipped Foxsat-HDR with a DLNA streaming package. If you stream a HD recording to a G2 box like the 1100S, you get the Audio described second MP2 track rather than the primary ac3 track. Fortunately Raydon came to the rescue with a package that recodes the recording in situ that switches the default track selected. Some Android Media play back apps allow you to select different audio tracks so using a smart phone tablet rather than the 1100S usb media player may fix the problem.
