Humax 1010S
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Maccboy, Jun 18, 2015.
Tags:
  1. Maccboy
    Maccboy
    Jun 18, 2015
    2
    Cheshire
    I have had a new Humax 1010s for just over three months, it's worked faultlessly until now, but it has started rebooting, and then hangs. I then need to turn it off and on, and then it will not select a channel.
    It eventually settles down, but then at any random time it starts again.
    Has anyone come across this odd fault?
  2. TJT1
    TJT1
    Jul 29, 2011
    4,825
    East Sussex, UK
    +1,139
    Apparently this is sometimes caused by a filing system/HDD fault.
    3 months? Take it back.
    Sometimes a reformat of the HDD fixes it, but you will of course loose all your recordings, but it's only telly.
    There is stuff about it on the Humax website and another well known forum that specialises in Hummy.tv I wont post a link as it will get deleted and I will probably have my bits chewed off.
  3. Maccboy
    Maccboy
    Jun 18, 2015
    2
    Cheshire
    Thanks for that I'll speak to Curries to get a replacement.
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    It won't help the very recent new software from Freesat is the issue. If you get a new box it will have the same issues. Only sensible option is to wait until Freesat and Humax sort out the problem.
    The effect varies between individual boxes. All seem to have lost all the onscreen icons, some with non humax WiFi dongles can't connect to the internet, others can. Some are experiencing issues with reboots or spontaneous shut downs. If your box is paired with the freesat app appears to have some sort of effect.
    My box has lost the icons. but is not suffering the reboot/shut down options.
    Best to look at the threads at MyHumax. Barry at this forum has close contacts with Humax is best placed to know the current situation.
  5. TJT1
    TJT1
    Jul 29, 2011
    4,825
    East Sussex, UK
    +1,139
    Thanks for the clarification on that GLT. I must remind myself not to dish out duff gen in future.:blush:
  6. logiciel
    logiciel
    Feb 2, 2008
    53,160
    UK
    +5,788
    Your bits are safe with me around!
  7. paffren
    paffren
    Jan 15, 2006
    113
    Derbyshire
    +22
    I have a Humax HDR1000S which has been working fine for ages but they did an OTA update on 15/6/2015 and since then it has lost WiFi connectivity, shut down randomly and cut short recordings. I reluctantly did a factory reset and lost all my scheduled recordings without achieving anything it still has all the new faults that came with this "update". I've phoned them, emailed and gone on Humax forums so they are aware of the problems and hopefully will do something to sort them out in the very near future.
  8. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    Loss of your recording schedule is normal during a reset. (During a reset you get the option to change your postcode, which could screw up your future recordings).
    For future reference take a digital photo of your current recording schedule, it helps a lot to re-build it).
    However in this case it clearly doesn't help. Note after a reset the box reverts to default settings including a shut down after 3 hrs of no activity from the remote (this can be turned off in the menus, and the volume output reverts to 50%) . I do wonder if this causing the issue for some.
  9. Jonstone
    Jonstone
    Feb 12, 2006
    4,164
    Prestatyn
    +549
    I just cancelled sky and I was planning on buying this box to use for freesat. Seeing the problems mentioned in this thread I am now a little hesitant.
    Would it be better to wait to see if these faults are addressed by humax , are all boxes affected?
  10. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,990
    Perchede 32460
    +456
    The issue with the dongle might not be - it relates to some add-on third party dongles which were impacted by improvements to Wi-Fi connectivity. Humax say they only test their own and cannot be expected to test a host of third party devices, some of which continue to function and some don't.
    The reboot problem, which was a issue for a few days, seems to have settled down and reports dried up. Some of us think it could be down to freesat tinkering or testing something releated to EPG changes.
  11. Jonstone
    Jonstone
    Feb 12, 2006
    4,164
    Prestatyn
    +549
    I see humax have released a new version the 1100s. On first look it does not appear to offer any features that are not on the 1010s
    Is there any reason to go for the newer model?
  12. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,990
    Perchede 32460
    +456
    Smaller unit, No SCART, Same Software.
  13. Faust
    Faust
    Dec 21, 2002
    3,526
    UK
    +763
    It is currently a game of chance whether any box you buy will be affected. I am like Graham and have only lost the tiny tiny icons in the front display (never used them anyway). For everything else the box is working normally.
    The Humax Freesat boxes are very good and I certainly would not be put off buying one simply because of a bodged update. Coming from Sky you should be used to those. :(
  14. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
