- Joined
- May 19, 2007
- Messages
- 6,432
- Reaction score
- 4,355
- Points
- 1,923
I've recently purchase a Pro-Ject Debut Carbon turntable and this is connected through a Pro-Ject Phono E box which outputs to a Samsung Q950T soundbar over an optical cable (The only way I get get audio into the soundbar).
The turntable is connected to the Phono box by the supplied phono cables, and I've used the incorporated ground wire to connect the turntable to the phono box as well.
All the devices (turntable, phono box and soundbar) are connected to the same 4 way adapter.
However there is still some hum evident from the turntable.
If I disconnect the ground wire from the phono box, the hum is very noticable, so this is doing something to help.
Is there a way to completely get rid of the hum?
I've tried the soundbar plugged into a different multiway from the turntable and phono box but it made no difference.
Any help would be much appreciated.
