HUGELY helpful SonicStage help info
Discussion in 'Headphones, Earphones & Portable Music' started by drmoze, Aug 28, 2005.
  1. drmoze
    drmoze
    Aug 8, 2005
    196
    Check out the forums at Atraclife.com. This fixed my "OpenMG Secure Module" non-install problem (see 'Returning my HD5' and 'SS doesn't see my HD5' threads below). Basically, I had to go into regedit and delete the Sony program reg info. All of this is in the software FAQ at atraclife.
    I also got a full SS 3.2 installer from the minidisc community forum (a sister site to atraclife), and it installed fine. Thought I'd give this one last shot. SS is running, but I'm afraid to see if it will recognize my HD5 or not.
    For those having installation issues with SS, the atraclife forum looks to be a big help. :smashin:
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    We all knew that. We're just waiting for the UK version specifically. Bet you have the US ver?
  3. drmoze
    drmoze
    Aug 8, 2005
    196
    Yup, US version. Didn't know that the difference was a problem. (I thought the regional versions only differ in the Connect music store stuff.)
  4. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,465
    +6,239
    it is mainly due to Connect being diff. and sometimes you can't register your player with diff region SS. Sometimes you can, sometimes you can't
  5. sulk
    sulk
    Aug 27, 2005
    42
    I live in Canada, so I doubt I'll be able to register my HD5, or use connect, as its not supported in Canada, which is a bummer, sine I wouldnt mind buying single songs now and again.
    -Sulk
  6. bruce1981
    bruce1981
    Forza Milan
