*HUGE* VGA D-Sub connector
Discussion in 'Desktop & Laptop Computers Forum' started by Alaric, Mar 12, 2001.
  1. Alaric
    Alaric
    Mar 12, 2001
    1,842
    Peterborough, Cambs, UK
    +186
    Hi there,
    In trying to make a 5m vga->bnc cable, i ordered one off maplin's web site without checking the size spec....The cable is excelent, 5 indervidualy sheilded 75Ohm coax's....only its 18.7mm in width which is kinda too big for the VGA connector.
    Anyone know where to buy a 15way D-sub connector with a huge cable appature ????
    Ta,
    Lee
  2. Guest
    Try SOLO LEADS in the UK! Sorry, but I cannot find their number, try directory enquiries.
    If I find the number I will post it here!
