Quantcast
Question Hue Routines
DoodleBox
I have just installed a Hue Outdoor Motion Sensor & a Hue Turaco White Led Smart Outdoor Wall Light which is nice :cool:
They both are setup on the Hue App and Bridge, & motion turns on the light, but that's where the nice stuff ends.
I haven't a bogs-notion about Hue routines & or IFTTT - can anyone help me with creating the following scenario ( if it's possible that is ) ;
Once there’s daylight, light bulb brightness should be set to zero
From sunset onwards, any motion detected turns the light bulb brightness to full.
The light remains on for 3 minutes afterwards, then light bulb brightness should be set to zero
