OK so I've gone Hue mad.
I was thinking of putting a Hue light bulb in the downstairs bog. You would simply open the door and the light would come on. It would obviously detect your motion (stop sniggering at the back).
Problem is, as I see it, if I take root in there with the Racing Post, and the light goes out, do I have to wave at it to get it to come back on?
I know I can set it to stay on for, say, 10 minutes, but that then seems excessive if you're just popping in for a quick number one.
Has anyone fitted one for this purpose, and how are you getting on with it?
