Hue light routine stops working.
tigermad
Hi. So only just getting into hue. Bought the floodlight. I setup a routine so that between 8pm and midnight the light is on dim. The problem is as soon as motion is detected on the sensor the light comes on full (which I want) but then turns off straight after the required number of minutes. Why does it turn back off instead of resuming the dim mode?
Inked
In the hue app under the settings section for the ligh does it not have an option to return to previous state when no motion is detected?
I don’t have the flood light but the hue motion sensors have this
tigermad
Works now. Thanks for that. So simple and was spot it. I have the separate motion sensor and changed the setting you showed.
