Hue bulbs and lamps compatibility
Discussion in 'General Tech & Gadget Forums' started by rEeee, Dec 15, 2016.
Tags:
  1. rEeee
    rEeee
    Oct 3, 2007
    98
    I bought the starter pack E27 from amazon. However I'm having hard time finding compatible lamps for the bulbs.
    Well I had two lamps already but I just can't find any new once in shops. I have been to B n Q, Homebase and other supermarkets. All that's available is the E14. Are the e27 not the standard in the UK. I just don't understand.
    I have looked at buying e14 to e27 converter which again isn't available in shops. I have to either buy it from eBay or amazon.
  2. BritanniaJaf
    BritanniaJaf
    Jul 12, 2004
    4,349
    Glasgow
    +318
    It's not just me then, yup in the exact same boat, searched everywhere but no joy in getting a decent lamp with a e27 fitting.
    Luckily I stumbled across the below thread on here last night which gave a link to a lamp on IKEA which takes the e27 bulb.
    Get your Phillips Hue's out for the lads.
    I tried at least 3/4 of those convertors from e14 to 27 and not one of them worked :(
    Am now waiting on the coloured bulb from Amazon turning up today to see how it all looks.
    Keep me posted if you find anything lamp wise, and I will do the same
