Ashleykr145
Hi All,
Ever since I performed the EMUI update to version 9.0.0.168 the bluetooth performance has significantly reduced. Tidal constantly skips with my Sony headphones and my use has not changed - same areas etc.
I have repaired the devices, restarted the phone and wiped the cache partition. None of which has helped. I do have high sound quality enabled to optimise for sound quality but this was never an issue before the update.
Has anyone suffered similar problem or have a suggested fix?
Ashley
Ashley
