huawei e 586 no network help
Discussion in 'Networking & NAS' started by boxer29, Jan 29, 2014.
  1. boxer29
    boxer29
    Sep 6, 2007
    342
    got this huawei e 586 which is unlocked, have been using ovivo Sim in it but for the last week its displaying on screen NO NETWORK and it is not connection to the internet ,Ive tried the Sim which works fine and it has a data package installed in it
    have also tried other Sim in the dongle but with no luck ,have rebooted and reset the modem ,
    did reset the network mode to manual in the setting ,but nothing seems to work
    is there any other way of fixing it
    have also updated the firmware from the 3 website but not luck
  2. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
    Sounds like your Dongle has died - No Network would suggest that it can't connect to whichever mobile network you sim is linked to. New Dongle required (it would appear).
