For Sale HUAWEI B715s-23c 4G+ Category 9 Gigabit WiFi AC 2 + external Poynting 5G Antenna
thesnodger
Rating - 100%
11   0   0
Joined
Jul 6, 2021
Messages
142
Reaction score
Points
Age
47
Location
Tarporley
Description​
I bought these 1 year ago when I moved into a property that did not have wired broadband available. The combination of the B715s and the 5g Antenna gave me consistent speeds up to 180Mbps in a poor reception area. In areas with better reception you can get up to 450Mbps from 4g using this router!!
The Poynting 5g Anntenna is 4g & 5g compatible, so if you upgrade your router at some point when 5g becomes avaiable you will not have to buy a new antenna. Check out the youtube video for best way to fit the antenna.
Cost over £320 when new, get this bargain now.
Huawei B715 Design
The Huawei B715 looks like a classic wireless gateway, there is no particular design or visual highlights. On the front side of the router, there are five LED indicators including power, network status, Wi-Fi, LAN/WAL, signal operation status indicators. On the back side of the router you will find a few ports (Power, LAN/WAN, USB, RJ11 ports).
But are there any difference with the B715 compared to other Huawei LTE router models like B525 or E5186 Huawei? The most distinct difference are the connection speed. The Huawei B715 LTE router can with reach up to 450 Mbit / s to use considerably higher speeds than the B525 and E5186. And it is in smaller size than the B525 and E5186 with the size of 155mm × 47mm × 240mm. It is overall as the top model among all the Huawei LTE CPEs right now.
Huawei B715s-23a Speed
As mentioned above, B715 is the LTE CAT9 router which offers an LTE Cat9 modem for up to 450 Mbit / s in the downlink. This is a remarkable improve above Huawei E5186 and B525s router. It is also supported 2*2 LTE MIMO technology. It also supports 4*4 MIMO antenna technology which is supported adjacent to 4 × also 2CC CA (ie, two times the channel bundling). In addition to support FDD LTE and TDD LTE at the same time, it could be used universally. Here are the maximum speed under different networks:
— LTE FDD: 4*4MIMO+2CA 582Mbps
— LTE TDD: 4*4MIMO+2CA 426Mbps
— DC-HSPA+: DL 42 Mbit/s, UL 5.76 Mbit/s
— HSPA+: DL 21 Mbit/s (64QAM) / 28 Mbit/s (MIMO), UL 5.76 Mbit/s
— HSPA: DL 14.4 Mbit/s, UL 5.76 Mbit/s
Huawei B715 Specifications
Network Band:
— 4G LTE Band 1/3/7/8/20/28/32/38 (FDD 700/800/900/1500/1800/2100/2600MHz & TDD 2600MHz)
— 3G DC-HSPA+/HSPA+/HSPA/UMTS: 2100MHz/900MHz
— 2G EDGE/GPRS/GSM: 1900MHz/1800MHz/850MHz/900MHz
Data Speed:
— LTE DL 450Mbps/UL 50Mbps
Features:
— Access to Gigabit Ethernet networks
— Complies with wireless 802.11b/g/n/ac standards with dual-band (2.4GHz and 5GHz)
— Support up to 64 wireless devices
— SMS
— IPv4 /IPv6 dual stack
— Compatibility with RJ11 telephone ports; support VoLTE voice (customizable function), can be set to Voice over Internet Protocol (VoIP) voice
mode or Circuit Switch (CS) voice mode
— Support for Huawei HiLink App
— WPS 2.0
— HOTA updates
— Built-in DHCP Server, DNS RELAY and NAT
— Security services. Provides instant protection to block potential security risks and intrusion attempts
External port
— One power adapter port
— Three LAN port (RJ45)
— One LAN/WAN port (RJ45)
— One telephone port (RJ11)
— Two connectors for LTE external antenna (SMA-female Type)
— One micro-SIM card slot
This will be poisted using Parcelfore, insured and tracked for £17.50 or can collect.
Please note I will only accept paypal if you are a verified user and agree to cover any paypal fees. Otherwise I accept cash on collection, EFT or Cryptop (BTC,ETH,BNB).
Location
Cheshire
Price and currency
179
Delivery cost included
Delivery is NOT included
Prefer goods collected?
I have no preference
Advertised elsewhere?
Payment method
cash, bank transfer
missin
Rating - 100%
25   0   0
Joined
Mar 1, 2003
Messages
215
Reaction score
7
Points
evening
is this still available?
can offer £150 inc delivery
marcdbl
Rating - 100%
7   0   0
Joined
Aug 17, 2008
Messages
177
Reaction score
12
Points
Location
Bristol
Hi there. Still available?
If so can you let me know what the model of the antenna is? Ta.
marcdbl
Rating - 100%
7   0   0
Joined
Aug 17, 2008
Messages
177
Reaction score
12
Points
Location
Bristol
Cool thanks. Need to check out the mounting for where I'm intending to put it. Will get back to you tomorrow morning.
marcdbl
Rating - 100%
7   0   0
Joined
Aug 17, 2008
Messages
177
Reaction score
12
Points
Location
Bristol
Sorry for the delay. Unfortunately the antenna isn't going to work with where I need to mount it so I'll pass. Looks like a great deal though.
