Thanks for the replies guys ,
OS XP PRO
IE 6
Zone Alarm Pro
McAfee Virus
Alexs MS recommend Clean Boot.
1.Run msconfig.
2.Click on Startup tab click Disable all.
3.Click Services tab, click Hide All Microsoft Services,Click Disable All
if button is not grey.
4.Click O.K. and restart the computer to Selective Startup enviroment.
5.Click O.K.To reboot.
6.When you see the message,choose Dont show this message or launch the System Configuration Utility when Windows starts and click O.K.
7.Test wheter or not the issue still appears inthis enviroment.
They also suggested I delete Cookies ,Files , History,&Objects.
Uncheck all boxes in Lan settings ,on the Advaanced tab Restore Defaults,and clear check box beside "Enable third-party extensions.
Click O.K. to save.Then run Adware to check for spyware......Jim
