HTPC with some component recycling
Discussion in 'Home Entertainment Computers' started by vaseston, Feb 17, 2014.
  1. vaseston
    vaseston
    Oct 20, 2006
    41
    It's been a long time since I have done any system building so greatly appreciate any advice.
    I am currently using an hp microserver under my TV as a htpc (non 3d ripped blu ray playing via xbmc). I added some extra ram, a SSD and a radeon 6450 fanless GPU and the system works well but is too noisy to leave on 24/7. I would like to get the microserver out of the room and use the ssd and GPU in a budget HTPC.
    The htpc will sit inside a wooden cabinet, so an ugly cheap case is fine , but small would be nice. What sort of motherboard and CPU should I look at? I am hoping to get away with something cheap as the GPU will be doing the work.
    Basically I am looking for a small budget case, motherboard and CPU to use with my existing bits. The system will either run windows 7 home as I have a spare licence or Linux.
    Many thanks in advance
  2. Navvie
    Navvie
    Apr 17, 2007
    935
    2
    Fareham
    +335
    Have you considered a fan swap on the microserver?
  3. vaseston
    vaseston
    Oct 20, 2006
    41
    I looked into it but not sure it would bring the noise down enough. The rI om is used a lot as a family room and I am always aware of the server when it is on. I would rather get it out of the way and have a system that is just turned on for xbmc duties.
  4. Navvie
    Navvie
    Apr 17, 2007
    935
    2
    Fareham
    +335
    Although I've changed CPU and graphics card, my HTPC was built over two years ago... I don't feel the need to build a new one at the moment so can't really comment on a modern spec. Have a look at some "spec check" threads on here, or with any luck somebody will chime in with a recommendation.
