HTPC with Intel Prescott
Discussion in 'Desktop & Laptop Computers Forum' started by jimbob19, Jul 11, 2004.
  1. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    I am in the process of speccing out a new system
    Already have Samsung spinpoint SATA160gb
    Asus P4P800VM matx
    512mb of ddr 3200 (2 sticks)
    Hauppauge PVR350
    MCE remote and USB ir reciever etc
    Now this is where I would like peoples advice , this m/b has inbuilt 5.1 - I will have to buy the header and feed the signal to my amp , now I am no audiophille , if this will be as good or better than the LG all in one I currently have - I am happy
    Also I am unsure wether to get the 2.8 prescott or normal pentium , not much difference in price.
    I will use the onboard radeon for vga output to my 32" tosh strata , then upgrade so I have DVI out , when I get a panny plasma .
    I am hoping to get a strata 390 case and silenx psu (depending on budget)
    Does this sound a reasonable setup ?
    :zonked:
  2. Kramer
    Kramer
    Prescots tend to generate more heat than their Northwood equalivents. More heat requires more cooling which usually means more noise.
    If you want to squeeze more performance from your cpu, Northwoods also seem to be more overclocking "friendly".
    :smoke:
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I went for the northwood over the prescott for those reasons.
    Machine is plenty fast for an HTPC in fact its a pretty mean gaming machine too: 6214 in 3dmark03 with a 9800pro in it ( with an arctic cooler).
    No overclock.
  4. ukbubs
    ukbubs
    I've got a machine with a prescott 3.0 512k cache, and one with 3.0 1mb cache. Both have the zalman flower cooler, and are on intel 865 perl mobos.
    The 512 cache runs at no more than 40dgeC with all fans set to run as slow as poss (incl the cpu cooler). :cool:
    The 1mb cache has the cpu cooler running full speed all the time. It idles at 48degC or so, and can go up to 60deg under load.
    Hope this helps.
  5. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    Looks like the 1mb prescott is def too hot then
    Ok will probably end up getting a 512k on a 2.8 - thanks for the info
    Will be running it on an Asus P4R800-VM - anyone have any idea how good
    the 5.1 is on board , it has spdif coax straight out
  6. ukbubs
    ukbubs
    I'd try it and see - you can always get a sound card later...... Unless I'm much mistaken, with spdif out, the clever work will all be done by your speaker setup anyway :)
    That mobo has ati9100 integrated graphics, right? You might even get away with not having to fork out for a graphics card, in which case you'll be running even cooler :cool:
  7. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    Yep thats what I was hoping :)
  8. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Prescott to me means large bloated useless lump!
    Would you buy something named after the deputy PM!!!??
