I currently have a Popcorn Hour A100 that I use for streaming video files from a Synology DS211 NAS. I run YAMJ with various mods which I am very happy with.
All works fine apart from 1080p BD files in an MKV container. It won't read them due to the processing power required. The solution is to remux the file into a TS container. All great as long as you don't mind losing the chapters and subtitles. This has proved to be a pain recently on a few movies I have wanted to watch.
So....
I am thinking about moving to a HTPC.
The spec will need to be something like this: -
Thinking of the following: -
Case: Silverstone LC16 or 17, OrigenAE
CPU: AMD Athlon II X3 Tri Core 450 3.20GHz (Socket AM3)
MoBo: Asus M4A88T-M AMD 880G (Socket AM3) PCI-Express DDR3
HDD: Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB
All so I have read various comments on merging the HTPC and NAS function into one machine due to noise issues.
If the HDD's are properly mounted using anti vibration mats (Rubber!) and the like, will this reduce the noise sufficiently? I will be running the machine 24/7 as it will be acting as the downloader for TV series etc.
Thank you as always for your comments.
Regards,
Simpic
So....
Hifi sized case to sit on top of my AV AMP
HDMI 1.4a output to staisfy the 3D requirement if I choose to use it in the future
Space for 4 - 6 HDD as I would like to lose the NAS and use this instead
Low power draw as possible
As quiet as possible!
Looks sexy >>> Wife's requirement!
Remote control by handset and wireless keyboard / mouse
OS - Not really too fussed, Linux or WIN, although I would like to run SABnzbd, Sickbeard and Couchpotato somewhere
Regards,
Simpic
